Why is my Buick over heating and coolant fans not working
Coolest fans not working and it overheating once in awhile
좋은 질문 입니까?
좋은 질문 입니까?
@stebb the very first thing you want to check is the fan itself. Connect a 12 Volt power source directly to the fan and see if the fan comes on. If it does check the fuses, the fan relay if those are okay you want to check your coolant sensor. Since you omitted the model, year and engine size we cannot assist you with specific details on where these parts are etc.
The ECT (Engine Coolant temperature) sensor is located on the top of the engine near the thermostat.
해당 답변은 도움이 되었습니까?
Thank you. I checked the fan, checked the fuse. Both are good. The fan relay is good too. Next step is the coolant sensor. It's a 2005 Buick Rendezvous
What did the problem turn out to be? Having a similar issue on my moms car, relays are good, sensor was changed, fan is good
2005 buick allure no air blowing on all sellections air button pushed in green light on but no blowing.
해당 답변은 도움이 되었습니까?
24 시간 전: 3
7일 전: 16
30일 전: 114
전체 시간: 6,201
댓글 2개
@stebb what year, what model, what engine? what have you checked?
oldturkey03 의
It's a 2005 Buick Rendezvous 3.4
Stevie 의
