주요 콘텐츠로 건너뛰기
Samsung의 주력 휴대폰 Galaxy S8. 2017년 4월 출시.
Sensors and iris scanner stopped working
It stopped working at the same time so i figured it might not be hsrdware related since they are separate hardware (iris is with front cam and sensors have their own sensory array). Everything under sensors dont give value (when using *#0*#) and iris just gave an error message (also in *#0*#). Ive done factory reset with no luck. Im out of warranty by the way since im not on the country of purchase. What would likely be the problem? Should I buy parts and replace them myself? Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 7개
First of all, we need to establish the exact issue. What happens when you try and use the Iris scanner? Does it fail instantly? Describe it in detail. If you dropped your phone it could cause the connection to become loose on the Iris scanner. Lastly, when trying to take a front facing picture does the camera work then?
Yes iris scanner fails instantly when im trying to use. Haven't drop it even a feet. Front facing cam is working, just the iris scanner won't. Ive done hard reset, running on safe mode, cleaning up cache on recovery mode and even reset to factory settings.
Try the lR light. Take another smartphone and point it at the module while trying to scan. The phone should be able to detect the light coming from the S8.
I use this trick all the time for TV remotes.
Not only my iris sensor is not responding, but also my auto brightness and S health sensor. Im trying to reset, clear catches data and still they are not working.
Have you find how to solve this problem. If yes can you tell me how to fix this problem please? My phone just got the same problem here.
댓글 2개 더보기
댓글 달기
답변 5개
가장 유용한 답변
I have the same issues too. I think this is the flaw/bug of the samsung S8. It happen sudently the same. Samsung need to pay atention to this and need to fix it.
이 답변이 도움이 되었나요?
점수 2
댓글 7개:
same thing happened to me with my samsung note fan edition . just recently went to samsung center , they hard reset it . still no luck . just waiting for head of samsung to make sure either my phone's sensor really faulty . think they replace with a new one . really hope so tho
sir any update to your phone? coz I have the same problem.
thanks
same my samsung fe.its happen after update with oreo..sensor back for blood measureament and the iris scan cannot detect the sensor.what would i do,please help me...
already factory hard reset,safe mode ,clear chace and also not install any third party apllication but its still cant solved this problem.
Samsung is TRASH. This is the third Samsung phone I have had that has broken for absolutely no reason. They released a bunch of new JUNK before they had enough time to correct the bugs. They either need to fix the problem via software, do a major recall, or get sued for billions in a class-action lawsuit. I am fed up with this company. They have a lot of nerve charging the prices they do for a phone that is complete and utter TRASH.
댓글 2개 더보기
댓글 달기
Try giving your phone an update, If that doesn't work you may have to get them replaced but may cost a small fortune. Take it into a shop and see if they can figure the problem out if this doesn't help.
Good luck :)
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
Im on latest update already, im pretty confident i can replace parts on my own but the problem is, they aren't selling sensory array part, its not out of stock, its just not there. Do you have other trusted seller for replacements? Thanks
@pccheese you know a solution to this, I can only think of missing drivers, but that should've fixed with a Hard reset, unless it's not detecting the sensors due to them being faulty. @fipssmaldone
@darkethereal On questions like this, diagnose the problem first. When we know what it is we can fix it, but until then find out what it is. Unless you know that replacing the modules will fix it, it is in general a last resort.
The problem is that sensor array and iris scanner is not working, like even in module test it fails (using *#0*# on dial pad). What more detail I could give?
댓글 달기
have you try to downgrade the firmware?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have the same problem with my s8 but my front cam is also not working. On *#0*# show gray eyes and shuts with error show changed 157 and revision $2 type and front camera failed on *#0*# also. I tried my camera module to other s8 it works flowsly may be its and hardware issue . Would you like to tell me where is the ic of front camera and iris scanner is placed
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Is your phone repaired? If you got the glass changed or cracked the screen , it can get damaged from moisture and stop working . IC isnt usually the issue as samsung builds these phones to be water proof the internal are pretty well insulated
댓글 달기
I have the same problem but with my iris scanner when I press start for it to scan my front camera doesnt show up at all, the 2 circles for my eyes stays blank and the scanner stays at 0% but my front camera works on my normal camera so I have no idea why I can't scan my irises. I did the full software update and everything, does anybody know why my camera isnt showing up to scan my eyes?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Your iris scanner is dead , it has nothing to do with the front camera , iris scanner is a seperate IR sensor.
If you happen to have dropper your phone or got the front glass replaced it can get damaged
댓글 달기
답변을 추가하세요
Filippo Smaldone Señagan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 31
전체 시간: 13,459
