주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Huawei Honor 8은 2016년에 출시된 안드로이드 스마트폰으로, 5.2인치 1080p 디스플레이, 4GB RAM, 12MP 듀얼 카메라 센서, 지문인식 센서 및 USB Type-C 포트를 탑재하고 있습니다. 모델명: FRD-L04.
Can't perform a factory reset
I have forgotten my password and as a result I am unable to reach my settings. I have not performed a back up and I have holiday photos on my phone I would like to keep. I have tried to perform a factory reset but I have been unsuccessful. What should I do?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
If you preform a factory reset you will loose your photos the only way in is to keep trying to get your password right
의
댓글 달기
답변 3개
선택된 해법
@preheat If you preform a factory reset you will loose your photos the only way in is to keep trying to get your password right . If you get locked out after to may failed attempts then go here then instead of factory reset in step 4 select wipe cache partition. do that and you will get a new round of password attempts . If you made the password you will eventually get it . Hope this helps
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Tryn to rest huawei android to factory settings but im stuck on formatting/data
의
It bypasses the scrolling option to wipe data
의
댓글 달기
[] Turn off your Android device. ...
[] Press and hold the "power", "volume down", simultaneously. ...
[] Release the buttons once your Android device is powered on. ...
[] Scroll using your "Volume up and down" button until you find the "wipe data/factory reset" option.
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
This will cause lose of holiday photos
의
yeah i concur... but assuming he cant remember his password how much choice does he have? he can keep trying though until he gets the correct password. And hopefully if he has to reset the device, he has a back up for his files.
의
I hope you dont mind I made a correction to your answer I removed the camera button part as this was incorrect but the rest was good
의
yeah I appreciate it man,... tnx
의
댓글 달기
hi, i have reset my honor 8, and now the first steps to log in with gmail account, but i cant continue because wifi is not turnin on!! i cant solve this problem. please help me :(
arberim_d@hotmail.com
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Lexi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 33
전체 시간: 10,137
