주요 콘텐츠로 건너뛰기
2011년 10월 24일 출시 / 2.2, 2.4, 또는 2.5 GHz 쿼드-코어 Intel Core i7 프로세서
405 질문 전체 보기
Missing capacitor on Logic Board
Hi,
My macbook had the GPU issue so i decided to use the oven method to fix it. To my suprise, i booted my macbook and no more graphic issues. My new issue is that the HDD is not being detected anymore. So i checked on the logic board and i saw the connector being loose because of the oven method. So i decided not to put it in the oven anymore but use a heatgun. So when i used the heatgun to put it back on, i accidentally hit some capacitors next to the connector and lost them.
Would anyone know what the capacitors model are? Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Thanks for the info and details. Would you know where i can purchase these? Unfortunately i am unable to find them online.
Cheers!
댓글 달기
답변 1개
가장 유용한 답변
@sch3ck this is not diagnose your logicboard since you've already done that. This is only to identify to missing components
Reference designator C4501 is a 0.1UF 10V 20% capacitor in a 402 package
Reference designator R4531 is a 4.7Ohm 1/16W 5% resistor in a 402 package
Reference designator C4531 is a 0.001UF 50V 10% capacitor in a 402 package.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Reiner Scheck 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 123
