주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 2.5 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.1 GHz).
Recovering files from formatted SSD rMBP Late 2012
Hi guys,
Is it possible to retrieve files from SSD on rMBP Late 2012? I have sold the computer itself but I have the SSD stick. SSD was formatted and OS installed so all my photos from travels around the world are gone.
I have tried using recovery software when I still had the computer but without any success.
Should I buy an enclosure/adapter for this drive and try again? Is there any other solution? I am willing to pay if I just could get my lost files back. Thank you.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Get an OWC Envoy SATA to USB enclosure. Make sure it is for your model as there are three different ones for the different sticks.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
When I have my SSD into the enclosure does it need to be connected to macbook or could it also be a widows machine to scan it?
댓글 달기
There is a case to hold your SSD made by OWC so you can at least gain physical access to the blade drive.
Recovering files from SSD's is harder than HDD's so its possible the recovery tool you tried just wasn't up to the task. I would talk with the company you bought the app from to see if there is a newer version and if it offers SSD recovery. You may need to look at other apps. Sadly, the ones you pay for are more likely to have the ability than the free versions. I would recommend this one: Data Rescue 5 for Mac
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thank you for the answers. When the SSD was still inside of the computer I used Data Rescue but it managed to find just the most recent files.
Does it make any difference if will buy an enclosure and scan it again using same recovery software? Will it return more results?
Any hardware solution to recover files that were there before formatting the SSD?
Well I'm happy you were able to recover something! Sadly, I don't think the case will help you at this point in recovering the rest of your files.
Give ProSoft a call to see what they say.
댓글 달기
답변을 추가하세요
Karolis 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 186
