주요 콘텐츠로 건너뛰기
Samsung에서 제조한 Samsung Galaxy Note 5는 (Note5로 불림) 스타일러스를 탑재한 phablet/패블릿 스타일 휴대폰입니다, 2015년 8월 출시.
271 질문 전체 보기
Why does my phone vibrate when it turns on after it was off?
So after I restart my phone, it vibrates when turns on, or when I turn it off (completely) and then on .
I don't know why it happens but I can give you more details if you ask me to.
It might be because of a specific application and because no one asked that so it might be because of oculus vr.
Why is it a problem?
Well after it happens my phone becomes slow for a short amount of time and then coming back to normal.
Please help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
Most Androids I have used will vibrate when powered on. This serves two functions:
  1. Tests the vibration motor
  2. Notifies the user that the phone turned on, in case it was an accident you wanted it off to save power.
First, remove any recently installed apps. If that doesn’t help, I recommend trying a wipe of the cache partition. This will clear out a bunch of temporary data and, although it will cause a slower boot-up the first time after being performed, will usually result in a much more responsive phone later.
Here are the steps:
  1. Turn off the device.
  2. Press and hold the Volume Up key and the Home key, then press and hold the Power key.
  3. When the logo screen displays, release only the Power key.
  4. When the Android logo displays, release the Volume Up and the Home key ('Installing system update' will show for about 30 - 60 seconds before showing the Android system recovery menu options).
  5. Press the Volume down key several times key to highlight 'wipe cache partition.'
  6. Press the Power key to select.
  7. Press the Volume down key several times key to highlight 'yes.'
  8. Press the Power key to select.
  9. When the wipe cache partition is complete, 'Reboot system now' is highlighted.
  10. Press the Power key to restart the device.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Try opening your device in safe mode. If it’s fine and everything, it’s likely an app like you said. If it persists, then you know it’s a different issue.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
You know that this post was a year ago.
I now own a Galaxy S9+ which doesn't do it.
댓글 달기
Why does my phone vibrate when I turn it on?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
My Name 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 48
전체 시간: 4,462
