주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1864, A1897. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
660 질문 전체 보기
Can I swap white front for black one, but keep the screen itself?
I had to settle for a Silver iPhone 8 Plus on Black Friday; I really wanted the Space Gray, mainly due to the black front panel and home button, but they didn't have any. I don't mind the "silver" (more like pearlescent white) back, but I'm having a hard time getting used to the white front. I know I could put a black skin on the front, but there's still the matter of the home button being white, plus I'm not sure how to use a glass screen protector and a skin at the same time.
Is it possible to swap out the white front panel and the white home button/fingerprint scanner for the black versions without having to also replace the LCD itself? If so, how much are the parts, and is it something I could do myself with the right tools (I have no experience repairing cell phones, but I'm good at following directions and know to use basic tools.) Also, where would I go to order the parts? Apple?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
가장 유용한 답변
You cannot swap out the home button or you will lose touch functionality. The button is married to the phone.
Glass-only swaps are technically possible, but extremely tedious and time-consuming. The glass is fused to the LCD screen, so it requires a lot of care and patience to remove without damaging the LCD.
I don't even bother to do glass-only stuff, it's not worth the time and effort.
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
Didn't know that about the home button. Thanks for the tip!
댓글 달기
essentially yes... however, the procedure is relatively difficult, requiring a variable temperature hot plate, steel Seperating wire, LOCA (Liquid Optically Clear Adhesive, and a large amount of practice. that being said, if you replace the home button, it will stop the touch ID from working without an Apple Certified Store doing the replacement.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Might it be less expensive to just replace the LCD panel as well (higher parts cost, lower labor cost)? And either way, what kind of cost am I looking at from an Apple Certified Store (or Apple itself)? Thanks!
If you plan on paying someone to do the repair, it will be near impossible to find someone who even bothers with the lens replacements. the labor costs are too high. but if you plan on doing it yourself, a lens is around 20$, so it is a lot less expensive.
In canada, our apple shops do the repair for $219. im unsure if that comes with the home button however. so you would have to contact them for any further pricing.
That being said, our apple stores also wont change the colour of the screen for you.
댓글 달기
You can put a colored glass screen protector of your choice on your iphone , i have a white glass screen protector on my black screen, i only didnt find a colored protector voor the home button.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Any links to these?
댓글 달기
I have a skin and a screen protector at the same time and yes it looks nice. Also. Using no heat and a pocket knife. I took off the front and back glass. Yes I cut my fingers. It is possible. Yes you can do it. Also I laughed when you asked if Apple sold parts. Steve Jobs made the first iPhone to stay locked in so no ones messes with anything in that case there’s no way they would sell parts you have to order replicas online. Not that they’re bad or anything. Some can be customized. It just takes what I did if you don’t have the big tools.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Chris 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 3,350
