주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Antenna not clicking into place while reassembling
HI,
I have replaced my lightening connector assembly, and when I'm trying to press the antenna into place it doesn't seem to "click" into position. It visually looks OK. It is step 35 of the the guide (iPhone 6s Lightning Connector Assembly Replacement).
I have tried connecting the antenna from the old lightening assembly to it which doesn't connect. This leads me to believe it is the logic board is the issue.
Any suggestions appreciated. Thank you in advance
Update (12/02/2017)
***Correction. I can get the old one to click in. So I think it could be something wrong with the new antenna connection, or the antenna cable length is slightly shorter making it extremely difficult to connect. Has anyone had any experience with this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
It does happen sometimes that the circular connector on the Antenna wire is "not so circular" anymore. that would certainly make it hard to snap into place. The problem with circles though is that once they are out of shape, it is very difficult to get them round again.
Take a look at the connector under magnification to see if it is in good condition. You could always take out the speaker to have more room to manoeuvre the connection. Once it fits in nicely, you can put the speaker back.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Ronan Kenneally 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 47
