주요 콘텐츠로 건너뛰기
모델 A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 또는 3.1 GHz Core i7 프로세서
212 질문 전체 보기
iMac late 2012 low voltage RAM memory and CL number
Hello,
I own this iMac: iMac 21.5" 2.7 GHz i5 (Late 2012)
After having a HDD failure I'm planning on replacing it with a SSD (Samsung SSD 850 EVO 2.5" SATA III 250 GB).
Since I'm opening the iMac to replace HDD with the SSD, I would like to also upgrade my RAM. Presently I have 2x4 GB (1,5V) and want to install 2x8 GB modules.
Apple's TN on RAM Configurations used in iMac late 2012: iMac (21.5-inch and 27-inch, Late 2012): Memory specifications
In article is nothing about voltage (1,5V vs. 1,35 low voltage) and CL number.
So my questions are:
  • Is it important, what number of CL is in RAM?'''
  • Is it possible buy low level voltage RAM? Or dual voltage?'''
  • Is it possible buy every RAM with proper specification (no matter how brand)?'''
For example, I could buy this for good price (second hand): Hynix original 8GB (1 x 8GB), 204-pin SODIMM, DDR3 PC3L-12800, 1600 MHz memory module
In the bottom of amazons link it is written that this RAM is suitable for my model.
Backward Compatible with 1.5V DDR3 Memory module: HMT41GS6BFR8A
Is it dual voltage? Kingston - HX316LS9IB/8 Module specs CL=9. Is it compatible?
It seems to be dual voltage (?)
THANKS
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
What you really should have looked at was the DDR3L RAM specs its self Vs the vendors RAM specs: Wikipedia - DDR3 SDRAM or get the real techie version here: JEDEC - JESD79-3F DDR3 SDRAM Standard
So simply put: DDR3L RAM can be used in either system! One designed for the older DDR3 RAM standard or the current systems which support DDR3L standard. The DDR3L RAM is able to support both voltages per the requirement within the standard.
But the reverse is not recommended! Putting DDR3 RAM in a DDR3L system! Besides the voltage difference the amount of heat put off by the RAM may effect things.
Standards are designed so everyone is on the same playing field! So vendor A's product will be equal to vendor B's and so forth... But its more than the standard its what the systems specs call out! That is your guide on what to buy.
Think of it this way... Gasoline comes in different grades low, medium & high. So if I have a car that the owners manual states I need the highest grade then I need it. If my owners manual states the economy version is just fine then it makes little sense putting in the highest grade of gas (RAM).
On the most part RAM is no different.
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
Ok, if I understand, DDR3L (dual voltage) will be fit with my model of iMac. Many webshops sell DDR3L, which they say, that it is fit to my model.
And what about CL (CAS) number? Is it important which number will be have my RAM?
Correct! DDR3L is what is mostly sold today as it makes little sense carrying two products in inventory where one will work in either system.
As far as the performance of RAM, stick with the Kingston RAM.
You don't need the top grade RAM in this system and you won't notice any difference as you're not over clocking the system. The Corsair RAM is designed for an overclocked system.
Correct, Last few months ago I have faced the same issue, one of my friends suggest to me one site, buykingston, I went through and solved the issue. The DDR3L RAM consumes lesser voltage compared to the DDR3. This reduces heating and enables faster operation.
@jackhardy - Almost! An older system won't run in the lower voltage as it doesn't have the logic to support it. A newer system requires the lower voltage RAM (review the given systems specs). The older system won't gain the benefits of the lower voltage which is all you'll gain here between the two if they are the same spec'ed RAM.
댓글 달기
Since my imac is 21.5 late 2013 2.7 GHz , means i can install any brand of DDR3L pc3 12800 SODIMM at 1600 bus speed right ?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Yes, thats what your system requires.
댓글 달기
귀하의 답변을 추가하세요
Matej Červeňák 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 10
전체 시간: 2,653
