주요 콘텐츠로 건너뛰기
Flashed wrong recovery,got into boot loop
I cant get into the recovery mode.there is nothing working in my tablet.when i power on it will show the mediapd logo..then stay on that screen and switches off automatically ...is there something i can do?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
there is a high likelyhood the device is bricked if you cant reaccess the download moad. in order to fix a bricked device, you would need to buy a Jtag, and flash it with that.
your cheaper option would be to send it to a shop that already has one, and the ability to use it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If you flash a wrong image into the recovery partition, you must try to start into the fastboot mode.
I believe the adb device driver is still on the PC available. After connect, you can reflash the recovery via
>fastboot flash recovery <image. name. of the right recovery>
which is in the best case in the same directory as flashboot on your PC.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
kannan rajan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 5
전체 시간: 1,507
