주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
Bent iPhone 7 plus
I recently brought my phone to the Apple Store for problems i've been having with my phone. They then discovered that I have a slight bend on the rear housing.
My initial problem was that when I turn it on the phone flashes a white screen with the apple logo. I've tried rebooting it through iTunes at times it will turn on and allow me to set up as a new phone but it doesn't stay on, and when it is on when i make or receive phone calls I can't be heard.
In addition the camera and voice recorder is not working, is there a possible solution to this? I'd rather not give in and bring it to Apple for repair. Any help is appreciated!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
A bent frame can cause logic board damage. It may be fixable but it's hard exactly what the issue is based on what you shared in your question. The only real option other than an Apple OOW replacement is to have it looked at by a reputable micro-solderer. The risk with bent logic boards is that the damage could be "inside" the board and therefore not truly fixable.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
For iPhone 7 bent frames, generally apple OOW is the way to go, I haven't found a way to bend them back in place.
Is there a way to test what the exact issue is?
댓글 달기
답변을 추가하세요
almarie 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 1,586
