The XV40 Camry was introduced at the 2006 North American International Auto Show alongside a hybrid version and went on sale in March 2006 for the 2007 model year.
이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Hi,
Are there puddles under the car when it is parked indicating a leak?
Can you see coolant stains anywhere such as around the radiator cap, hose clamps, radiator core, engine block etc, indicating a leak?
Check the radiator / coolant system hoses for cracks and splits.
Get the cooling system pressure tested to ensure that there are no leaks.
Check the engine oil dipstick to see whether it shows the oil to be a milky colour or that it shows that there is a brown residue above the oil level line indicating that there is coolant leaking into the engine
Hi,
jayeff 의
