주요 콘텐츠로 건너뛰기
Released June 2016, identified by model number A3003 in Europe, A3000 in China and North America (according to https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
66 질문 전체 보기
Dissabling the microphone on the OP3
Hello,
I read this story on wired How to Rip the Mics Out of Your MacBook and iPhone . Would it be similar for the OP3?
This is because I could find any obvious cables on the dismantling tutorial.
Cheers!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
How Can I'll be Correct Microphone
댓글 달기
답변 1개
선택된 답변
Hi @radconnorcon ,
According to this link the microphone is on the charge port flex cable.
Here is a link to the ifixit Oneplus 3 Teardown guide. At 4:11+ minutes into the video the microphone is accessible.
You could always try gently (stress gently) permanently removing the microphone from the cable and then re-assembling the phone. (I doubt that the microphone would be able to be reinstalled successfully - you'd most probably have to install a new charge port + microphone flex cable)
Hopefully the phone should still work if you use the earphones with the microphone attachment if you feel the need to make or receive calls.
Alternatively you could just simply block the phone's voice inlet hole on the bottom of the phone with glue or perhaps as a temporary test measure, clear adhesive (sticky?) tape to prevent sound reaching the microphone. This should achieve the same result with less potential damage from having to open the phone etc, occurring
Glad I'm too old and hopefully considered not interesting enough for it to be worthwhile to be bugged by anyone. Life's simpler this way. Cheers ;-).
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Conrad Connor 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 7
전체 시간: 859
