주요 콘텐츠로 건너뛰기
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
428 질문 전체 보기
Screen freezes and pixilates.
My original 360 will turn on, but after about three to five minutes, it will completely seize up, and there is an aweful buzzing noise coming from my speakers. The screen also becomes distorted with lines running through it. If Anyone can help I would be appreciative, thank you.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
it sounds like you are on the fast track to getting rrod.
They sell a fix kit Here you might want to try. And a guide for it here. Hope all goes well.
Good Luck,
Cody
Xbox 360 Red Ring of Death Fix Kit 이미지
상품
$29.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
+ agree with Cody on that one.
댓글 달기
That fix is not permanent. In fact, not even a reball with leaded solder is permanent, albeit it's the longest-lasting solution.
This method is basically just forcing the motherboard to warp so that the broken solder joints under the GPU touch.
A reflow of the GPU is a way better fix. Most people charge $35-40 for this on craigslist. Make sure they use a real reflow station with a real preheater and not a heatgun with electric griddle.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
corbin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 3,939
