A 2006 xserve optical drive caddy install
I have a 2006 xserve (emc2107) . I just ordered 2 optical drive HDD cady's for the 2008 20" iMac(emc2133). Both xserve/iMac use the same connector (PATA) for the optical drive. My question is, does anyone know if someone else has tried this and/or is there some complication I might run into?
좋은 질문입니까?
댓글 2개
A bit confused on what you are trying to do here. Your question mentions the optical drive, as well as the HDD. Are you trying to install a new optical drive? Or a new HDD?
Andrew Afonso 의
I am thinking of replacing the optical drive w/ a ssd I have laying around. From what I've read you cannot replace the hot swappable HDD's with just any drive, apple approved drives only(from my research). I mention that b/c I'd just leave the optical alone and clone one of the HDD's if I though it'd work. So, to answer your question I'm wanting to replace the optical drive with a drive caddy/ssd.
Pete 의
