주요 콘텐츠로 건너뛰기
OSX Upgrade on 2006 xserve
I have an xserve 2006 (emc2107) running MacOSX 10.7.2 Lion Server. I read that it can be upgraded to 10.7.5. I burned a copy of 10.7.5 client upgrade and 10.7.5 server upgrade. Here is the good part, I mislabled the disks. So I used 10.7.5 client upgrade on the xserve running 10.7.2 Server. Is there a way to recover my server os? I hope that just installing the 10.7.5 Server upgrade will work but I don't wanna make things worse. Basically if anyone can give me some advice I would greatly appreciate it.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Does anything show up in the software update app?
Do you still have server.app? If so, try just opening it.
Starting with OS X 10.7, there is not really a "Server OS", the server software is simply added to the normal Lion OS, so you should be fine.
Also, in "About this mac", what is listed as the software?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I will check that out tomorrow morning and get that information to you.
댓글 달기
귀하의 답변을 추가하세요
Pete 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 297
