주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
Why does my iPod show a red "x" in a circle?
My 80 GB iPod Classic shows a red "x" in a circle and won't go into disk mode. Does that mean the hard drive is bad? It happened when I connected it to my computer and upgraded iTunes to 9. I am using Windows XP.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 18
댓글 2개
Can it hold a charge?
ipod not working fix x symbol
댓글 달기
답변 4개
선택된 해법
Well, I believe you have a 6th gen, slim 80 GB iPod classic. If I am correct, iTunes 9.X (Whatever version) should be able to work with it. When a red X appears on your iPod screen, especially the 6th Gen classics, it is usually a hard drive failure. If it charges, you know it's not the battery. Try formatting it with Windows, then do a restore on it from iTunes. If that doesn't work, try giving it a good hand slap on the table (with the sync port pointing down to the table). I know this might sound barbaric, but the needle in your hard drive might have been displaced and needs to be realigned. Also, the hard drive cable that connects your hard drive to your logic board might be slightly loose. Doing this will help you connect. If all else fails, which I hope it doesn't, then I believe you should sell it on eBay or try to replace the hard drive. A hard drive for this model can be found here.
Replace a broken or damaged hard drive for your 80 GB iPod Classic with this part. 이미지
제품
iPod Classic 80 GB Hard Drive
$20.99
iPod Classic Hard Drive 이미지
안내서
iPod Classic Hard Drive Replacement
난이도:
매우 어려움
50 minutes - 2 hours
iPod Classic Hard Drive Cable 이미지
안내서
iPod Classic Hard Drive Cable Replacement
난이도:
매우 어려움
이 답변이 도움이 되었나요?
점수 48
댓글 101개:
I love the "bash it against the table" solution- it's worked several times for me. 1+ vote.
Trey you are the man!!! I bashed my iPod classic 80gb....I had nothing to lose as I had the red X and it wouldn't restart..so I read your advise and smack! Next thing it makes this noise that I'd never heard before...like a fax modem then it's good as new! You are a champion, thanks heaps!
that was CRAAAZZYYYYYY!!! my iPod was whacked out and then i did the smack on the table... it made a sound like dial up internet and then i heard a familiar whirrr of the hard drive spinning properly. YEA!!!
How should it be smacked or on what??
Trey thanks very much you are clever man i did your intruccions and work so well
댓글 96개 더보기
댓글 달기
here is a "howto" video: http://www.youtube.com/watch?v=RZDYk4-kc...
이 답변이 도움이 되었나요?
점수 3
댓글 달기
somebody has to open the iPod and replace the hard drive. The cheapest way is to do it yourself and you should get away with around $70. The part is available on ebay. Here's a iPhone Repair guide on http://www.portatronics.com/guide how to disassemble an iPhone. Maybe a tech savvy friend can do it for you. If you want to pay to have a service do it for you there are third party Services such as ifixit.com
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Sorry Michael, I think you may have misunderstood the modus operandi of this website. iFixit offers no repair service of any kind, but rather provides well documented and photographed repair guides, as well as the parts necessary to complete these repairs. For example, relevant to hard drive failure of this particular iPod model, there is this guide and these parts.
댓글 달기
If Your iPod Displays a Red "X" Icon:
http://support.apple.com/kb/TS1463
1. Put your ipod into disk mode
If you don't know how to put your ipod into disk mode:
http://support.apple.com/kb/HT1363?viewl...
2. Connect it to your computer
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
and what if i cant transfer it into dsik mode at all... tried 5 times now!
댓글 달기
답변을 추가하세요
Rita4259 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 14
지난 7일: 83
지난 30일: 377
전체 시간: 225,489
