주요 콘텐츠로 건너뛰기
The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
20 질문 전체 보기
Stuck on Samsung Galaxy tab 2 10.1 logo
My tablet is stuck on Samsung galaxy tab 2 10.1 logo I can't do a reset but I can do a Odin I can't do a reset because when I hold down the power button and it turned off it will open again stuck on the logo again and if I try it in Odin it goes to the options but factory reset can't I tried the hold the power button and volume up and remove power button and hold the volume up and it will do the Samsung logo and at the top left there will be a recovery booting its color blue but after that it will go to the Samsung galaxy tab 2 10.1 again and if I do the same thing the same thing will happen again
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
Hi @laizander ,
Try disconnecting the battery from the tablet's systemboard for a few minutes. Then reconnect it and try a reset. (You only have to disconnect the battery connect cable, you do not have to remove it from the tablet)
Here is a link to the ifixit Samsung Galaxy Tab 2 10.1 Battery Replacement guide which may be of some help
이 답변이 도움이 되었나요?
점수 2
댓글 달기
you can try accessing the reset menu by holding a power and volume up or down. not sure which one. you can try a factory reset that way. you could also try flashing the stock firmware to see if it is a problem the software.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Laizander 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 4,665
