Full battery but won’t turn on
My s95 camera worked well last time I used it but now won’t turn on. I have already ordered a new battery and installed it but still no go. Is there an easy check I am missing?
좋은 질문입니까?
좋은 질문입니까?
Ned Hascall start by checking the battery contacts as well as the battery door. If it does not make proper contact your camera will not get any power. Let us know what you get once you've replaced the battery.
이 답변이 도움이 되었나요?
I am a having a similar issue and have replaced the batteries. Is their another step I can take?
@Chris Cool Did you check the battery compartment door? If it does not make proper contact it will not work
Yes I checked the door and it made contact but I was never able to get the camera working
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 1,004
댓글 2개
I’m having the same issue with my s95. Battery door compartment is all fine but still won’t turn on. Has anyone found a solution please help a girl out :(
Christina 의
@christina73227 does your S95 give you any sign of life? Checked the battery, just to make sure?
oldturkey03 의
