주요 콘텐츠로 건너뛰기
Released in 2014, identified by 11.6 inch screen, 2-in-1 convertible touchscreen laptop. Model number 11t-n000.
23 질문 전체 보기
How to replace a cracked screen?
Hey! I dropped my HP Pavilion 11-n011na x360 and unfortuantely there are two cracks on the screen, I was wondering how I would find the exact replacement screen as I've seen a few different ones and I'm completely clueless when it comes to this type of thing and how I would go about actually replacing the screen, I haven't seen any guides on the HP site or here.
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
댓글 달기
답변 2개
선택된 답변
Hi @lecollecteur,
The service manual gives instructions regarding the necessary pre-requisite steps and then the procedure on how to remove the LCD screen. (see p.58 in the manual)
On p.15 of the service manual, you'll find the 4 types of LCD screens used for the different variants of this model. To be absolutely sure that you have the correct one for your laptop, the part number will be stamped on the back of your LCD screen. You'll have to dis-assemble the laptop to remove the screen to find out of course.
Once you are satisfied that you have the correct part number, search online using just the part number only, to find suppliers of the part that suit you best.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Hi try to check this service manual..
http://h10032.www1.hp.com/ctg/Manual/c04...
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
lecollecteur 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 2,293
