주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
iPhone saying Connect to Itunes in setup.
Hey all! I have a iPhone 4 that says "Connect to iTunes" In setup. When I do it says There is a problem with your iPhone. This phone has never been dropped and never encountered water. The IMEI DOES SHOW when you hit the blue I But the iccid does not. Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
first step, is enter DFU mode, and run a restore. A restore is better than a reset, as it installes all new firmware, rather than utilizing the current firmware. should you have a corruption in the core files of your firmware, a reset will not fix it, while a restore will.
To enter DFU mode, follow these steps
1) Plug in the device.
2) Power down the iPhone
3) Hold the power button until you see the apple logo
4) without letting go of the power button, hold the home button for 10-15 seconds. (until the screen goes black)
5) Without letting go of the home button, release the power button, and continue holding the home button for 15-20 seconds.
If you have done it correctly, your iphones screen will be pure black, and your computer should be installing driver software.
From here, run the restore process, as instructed on itunes.
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
I have already tried this multiple times. But thanks for your help!
then from there, with a device of this age, you are likely looking at board degregation. The Apple server will always verify the install, and if it feels the board doesnt have the proper hardware, then it will cancel out. this can be either a third party part or cord that causes the issue, or even just the components on the board reading above or below the voltage threshold they are supposed to.
So basically the board is shot??
essentially, that is the highest likelyhood. but you can look into things like custom software loading, and the like. i dont have that kind of experience, as i deal strictly with OEM software work.
댓글 달기
귀하의 답변을 추가하세요
Ethan Leroux 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 165
