주요 콘텐츠로 건너뛰기
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 질문 전체 보기
Put in 2000mAH big battery in iPod 3gb
hello can i put in a bigger battery in the ipod 30gb 5 gen , like a 2000maH or an iphone 5 battery??? where can i find such a bigger battery for the ipod video 5gen???
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
valantis sourlis no you cannot. The space is extremely limited on this model. You must stay with the original battery. If you want to update to a battery from a 60GB or more of the same generation you need to replace the back cover since it is deeper to accommodate even that small size difference.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
If your battery life seems shorter than it used to be, you can replace it! iPod 5th Generation (Video) Battery Replacement
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
i tried ordering it on ifixit eu store but it says not available, where can i get a big battery else where for shipping to europe?? want a good quality one,also is there a cheap way to put more gb in the ipod???
iPod 5th Generation (Video) Hard Drive Replacement This guide will show you how to replace your HDD with a new one, But I cannot get the price for you on the EU store because its in a different language. (google translate extension is only translating some of the pages)
댓글 달기
Just trying to think out side of the box here. You can add a bigger battery if you are creative. It may not look pretty but all you need is a external battery for example. Use adhesive or place it in a separate pocket.
Big external battery
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
If you flash mod the ipod, there's a lot of extra space. Then you can get a big chungas battery if you want.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
wasou 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 661
