주요 콘텐츠로 건너뛰기
2015년 3월에 발표, 2015년 4월 10일에 출시된 Galaxy S6은 Galaxy 라인의 다음 주력 제품입니다. 곡선형 스크린 버전은 Galaxy S6 Edge로 알려져 있습니다.
487 질문 전체 보기
solder old nand flash on new motherboard
Hi,
My samsung galax s6 took water damage, but I want to retrieve the data on it. I already tried to replace the battery and usb connector unit. Both didn't work.
My last resort would be to buy a cheap 32GB mortherboard on aliexpress. And remove the 128GB nand flash from the broken phone and solder it on the 32GB motherboard.
1. Will this work in theory?
2. Can this job be done by someone with next to none soldering experience? btw, I dont care if i will screw up, because I see it as the last resort anyway.
3. Or do you have other suggestions to get the data back, which are not expensive.
Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Is there any way to fix the water damage?
Electronics Water Damage
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks, I already cleaned en submerged the boards with isopropyl alcohol. I couldnt really reach the processor, nand unit etc. though, since they are under a protective shell.
댓글 달기
did you already try this? I'm in the same boat. I will try this today a let you know what happens
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Did you have any luck with this?
댓글 달기
귀하의 답변을 추가하세요
Mar Do 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 379
