주요 콘텐츠로 건너뛰기
Guides for the Wi-Fi version of the iPad Mini 4—model A1538. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
97 질문 전체 보기
What is the best way to adhere home button to new screen?
I have replaced the broken screen/digitizer on my ipad 4 mini, however I am trying to find the best way to attach the home button to the new screen. The home button is still affixed to the flexible gasket, and the flex gasket is still attached to the flat washer-type piece that adheres to the glass, so I just need to attach the washer piece to the glass. I need something thin enough to keep the button flush to the surface (not sunken in the hole of the new glass), yet strong enough to hold for the long term. I'm afraid if I use glue, it will stick the sides of the button to the glass. and not allow it to move at all.
I also need a solution for the worn out adhesive on the button bracket. Not sure if I should use the existing tape to hold it place and glue around it or scrape off the tape and start with something new.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
I like to use quality adhesive for the bracket. You have to clean off all the old adhesive to insure you get good grip. If the bracket holds firmly, even the residual adhesive on the gasket and washer will suffice. I use the pre-cut templates from BowlerTech. I specifically get the bulk kits that include the extra tape that was not trimmed so I can make a custom cutout for the mini 4 bracket. BowlerTech also offers the extra trimmings separately. Or you can use Tesa Tape sold here on iFixit but you have to buy a whole reel.
Tesa 61395 Tape 이미지
상품
Tesa 61395 Tape
$5.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
You typically use a special double sided tape used to adhere to screens and other items. Here is an example.
https://www.amazon.com/Adhesive-Touchscr...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
TonyM 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 36
전체 시간: 6,729
