주요 콘텐츠로 건너뛰기
Repair guides and support for the laptop line of Acer's Aspire series for casual home and business use.
1192 질문 전체 보기
Hard disc drive replacement not SSD.
Hello everybody,
My Aspire One 110 laptop's SSD has crashed and I'm looking for a valid replacement.
All topics I've found browsing are a couple of years old and I'm not sure about witch or where buy a new one, that I can use with this tutorial .
Thanks.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
It looks like it uses a standard 9mm 2.5" laptop drive such as this: 750 GB 7200 RPM Seagate SATA Hard Drive (New)[연계 제품이 누락 또는 비활성화 됨: IF107-099]
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
looks like the 110 does use a standard hard drive: http://www.sparepartswarehouse.com/Acer,...
Hi again Mayer,
I have a 110 model.
Does it changes the guide steps a lot of?
Thanks.
Thanks for your answer, mayer,
just one little question. Does the hd has a zip connector? I've read in many places that I need this connexion for my laptop.
I liked this HS 320GB because is not my main computer.
Thanks for you time and best regards.
You have actually given two machines, your link is to a D150 the guide is to a 110. I gave an answer for the D150. What do you have?
댓글 달기
귀하의 답변을 추가하세요
pdeandres35 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 4
전체 시간: 3,083
