주요 콘텐츠로 건너뛰기
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
205 질문 전체 보기
Why won’t my 2ds turn on? Are there any ways I can fix my problem?
Hello. I have had my 2ds for under a year and I have encountered something nasty that I’d like to know how to fix. My system will turn on but the screens will be black, there will be no volume, and the little orange light on the side isn’t on. Also the (blue) power light is on throughout this whole time. I have tried turning on and off my system multiple times but it will not work. Please tell me how I can fix this, my last option is getting it repaired but I’d like to know how (or if) I can do it myself. Thank you in advance whoever answers this question! (Side note: My first 2ds had a similar problem to this except that one wouldn’t turn on without being plugged into the charger and eventually it just gave out. Also, I don’t know if it really effects anything but I’ve encountered both of these problems while on the 2ds’s YouTube application.)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
I have a n2ds and it will charge but won't turn on is the a way I can fix it my self or do I have to buy one?
댓글 달기
답변 1개
선택된 답변
Hi @chickenramen ,
Nintendo systems have a 12 month manufacturer's warranty.
First verify that your system is still within the warranty period (check the date on the purchase receipt).
If the warranty is still valid, consult the manufacturer's warranty statement (usually found in the User Guide) that came with the system, as to what you have to do to make a claim for a manufacturer's warranty repair, replacement or refund.
if you can't find the warranty statement, search online for Nintendo 2DS warranty .
If you open the device to find the possible cause of your problem you will void the warranty.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thank you so much, @jayeff!
댓글 달기
귀하의 답변을 추가하세요
Kenny McCormick 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 5,775
