주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wi-Fi 전용 버전의 Apple iPad Air(모델 번호 A1474)입니다. 스페이스 그레이 또는 실버 색상으로 제공되며 맞춤형 A7 프로세서가 탑재되어 있고 16, 32, 64 및 128GB 용량으로 제공됩니다.
Red lines with booting
Dear people,
When i was charging my iPad Air 1 this screen came up.
It totaly freezed up and with the powerbutton and homebutton pressed in it finally turned off.
I've been trying to charge the ipad for 1 day on the charger, didnt work.
Then i removed the screen and disconnect the battery, didnt work.
Does anyone have an idea how to fix this?
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
I haven't seen this screen pattern before so I can't offer up a "solution". Did anything happen to the iPad in the days or week prior to this issue? Perhaps it was dropped, damaged, contacted water or was repaired.
At any rate, this device has to be opened up and tested. Perhaps it's the LCD but I suspect a logic board issue. A repair shop that does micro-soldering repairs should be able to troubleshoot this.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Minho! Thanks for your reply!
Nothing happend to the iPad it was just charging.
Do you know which IC or is it the charging electronics?
Like I said, it could be multiple things and I haven't seen this pattern before. It could be a damaged LCD, LCD drive circuit or a flex/connector issue.
댓글 달기
답변을 추가하세요
Luuk Toonstra 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 526
