주요 콘텐츠로 건너뛰기
Released in September 2009, Samsung's GT-E2120 features an embedded FM radio internal antenna along with a Bluetooth wireless connection.
4 질문 전체 보기
Phone displays splash and reboots blinking endlessly.
This seems to be a well-documented problem.
This phone will power up to the splash screen, and then reboot. This process repeats until the battery is physically removed.
I have a USB cable, but no other hardware.
There are two phone numbers I would like to retrieve from this phone.
How can I recover the two phone numbers without additional hardware? I'm thinking some specialized flashing software/hardware is needed. I hope there's an easier alternative.
Thanks for reading!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 8
댓글 1개
i have a similar problem in my gt-e1200. its stuck in a bootloop. how can i fix this? do i have to remove a cap or something?
댓글 달기
답변 4개
가장 유용한 답변
Ikvee from what I remember there was some hardware problem. Something about a capacitor or resistor on the logic board that needed to be replaced/removed in order to fix this. I will try and see if I still have it bookmarked. Once it stops that reboot cycle, you should still get to your information re. your two numbers. Okay here oops I meant here is the thread that I was referring to and apparently here is the cap to be removed. Again, no guarantees but it could work.
해당 답변은 도움이 되었습니까?
점수 5
댓글 6개:
Did you forget the thread?
I have same problem but i'm afraid not to damage my phone by removing this part. Did someone tried this?
I did and it works. Just be careful not to damage the phone's motherboard.
xcellent, great job and congratulation
its not working
after remove cape what to do?
댓글 1개 더보기
댓글 달기
I factory restarted my chat222 GT-2222 samsung moblie but my phone continue to splash the image "samsung chat222 GT-2222
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
sorry, this is a question
댓글 달기
Accoring to the service manual that's a bias cap for the microphone...how does removing this solve the problem of the reboot screen and what's the impact on the mic when you go to use the phone again?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Apologies...teh above answer shoudl really have been a question/comment :-) According to the service manual that's a bias cap for the microphone...how does removing this solve the problem of the reboot screen and what's the impact on the mic when you go to use the phone again?
Thaks in advance and apologies for wrong posting...
댓글 달기
I want to ask. Everytime I start up my GT-1200T it's keep on booting or the samsung word keeps on appearing. How can I solve this?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
lkvee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 14
전체 시간: 29,474
