How to remove inside calcium from a Hankscraft automatic steam vaporiz
How to remove inside calcium from a Hankscraft steam vaporizer humidifer Model 5592
좋은 질문 입니까?
좋은 질문 입니까?
im not sure about this specific model, but for a generic humidifier, vinegar works.
Pour a generous amount of undiluted white vinegar in to the base of your cool mist humidifier and let sit for 30 minutes. Then remove any residue or build-up by gently scrubbing with the soft bristle brush. Rinse thoroughly. Gently spot clean any remaining pieces and thoroughly rinse the tank, filter, and base.
해당 답변은 도움이 되었습니까?
I may not have provided the complete question. I need to remove the calcium deposit on the steam unit that fits into the base. The steam unit has a couple of screws that hold the steam unit and casing together. Sorry about that.
Unfortunately, i do not have access to the User Manual to share the exact disassembly process, so a manual clean isnt something i can guide you through.
if your user manual doesnt have a disassembly guide, for cleaning, i would suggest calling the manufacturer for further instruction
Try simply spraying some CLR on it and let it sit. It should eventually dissolve the calcium buildup without disassembly.
해당 답변은 도움이 되었습니까?
i WILL GIVE IT A TRY. THANKS FOR YOUR SUPPORT. WILL LET YOU KNOW IF IT WORKS
Your answer requires the highest award that I give. A GOLD STAR
Thanks so much.
Earle
해당 답변은 도움이 되었습니까?
Which solution? Vinegar or CLR?
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 1,012
