주요 콘텐츠로 건너뛰기
구글 픽셀은 2016년 10월 20일에 출시된 구글의 첫 번째 플래그십 스마트폰입니다. 5인치 AMOLED 디스플레이 장치에는 32GB 및 128GB 스토리지 옵션이 제공되며 베리 실버, 콰이트 블랙, 리얼 블루의 세 가지 색상으로 제공됩니다.
Phone call is taking time to show controls and connecting
I am using Google Pixel mobile. When I try to make a call from default phone app it is showing screen with Contact name & number for 15 to 20 seconds (attached the screenshot for your reference) and then it showing other controls. After that only call functionality is working.
I tried with uninstalling phone app updates first and then updated the app again. Still issue is not fixed. Is there any workaround for this ?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi,
Try starting the phone in safe mode and see if it performs normally when making calls.
If it does then a downloaded app is the cause of the problem.
The trick is to find out which one
First backup the phone as a safeguard.
Then with the phone in normal mode, you need to uninstall each downloaded app one by one and test the phone after each uninstall to see if it works correctly.
When it does then the last uninstalled app is the culprit.
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
Uninstalled all the newly installed apps but no luck.
Hi,
Can only suggest that you backup the phone using the phone's backup feature and perform a factory restore using the phone's factory restore feature.
Then test if the phone works OK.
If it does then restore the phone from the backup that you made earlier and see if it works OK after the restore.
If it does then a factory restore has resolved the problem
if it still doesn't work correctly after a factory restore then there is a problem with the phone. How long have you had the phone? Check the manufacturer's warranty on the phone for your location and if the warranty period is still valid then follow the directions of the warranty about making a claim for a manufacturer's warranty repair, replacement or refund
Recently I got a security update. After that update one of my existing apps is causing the issue. First i tried with uninstalling newly installed apps but no luck. After that i uninstalled older apps as well. Then issue got fixed.
No need of factory reset!! Thanks for your answer.
Hi,
Thanks for the feedback.
Hopefully it wasn't the last app left to be uninstalled that was the cause of your problem.
Cheers.
댓글 달기
답변을 추가하세요
Gopal Gajarao 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 170
