주요 콘텐츠로 건너뛰기
다섯 번째 Google Nexus 휴대폰. 2013년 10월 31일에 공식 발표되었으며 4.95” 1080p 스크린, 2.26GHz Snapdragon 프로세서 및 LTE 지원을 자랑합니다. Android 4.4.2, KITKAT. 제조사는 LG.
222 질문 전체 보기
[Solved] Nexus 5 Screen is not working properly!
Hi,
I am not able to understand why my Nexus 5 screen doesn't work properly. It seems that the phone is working as I could hear some notifications. What could be a fix for this problem?
Update (01/20/2018)
Changing the flex cable solved this problem!
Thanks guys for your comments.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Hi @mgupta70 ,
Has the phone been dropped or gotten wet at all?
Hi,
The phone hasn't been under any water or physical shock/damage.
Still I am facing this problem. And it is not a software problem, I believe. I tried all sorts of resetting techniques.
I am not sure what to repair, the flex cable or replace the LCD/touch assembly entirely. Any help in this matter is appreciated!
댓글 달기
답변 1개
선택된 답변
Hi Mohit @mgupta70 a screen just going bad doesnt happen very often without a catalysis . SO lets assume the worst and start to tear it down as if we are going to replace the LCD They can be purchased onebayfor as cheap as 30 dollars This guide can help with the teardown
Nexus 5 LCD Screen & Digitizer Assembly Replacement
But as were not sure this is the whole problem examine the logic board closely as you tear it down . Look for corrosion or discoloration .Next make sure all cables are connected securely and correctly as you disconnect them. Look for rips or tears in ribbon cables check for cracks in any folded ribbon cables. Check for any changes in color and or burn marks . If all seems fine then proceed with the screen replacement . Hope this helps
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thanks for your comment!
I have ordered a flex cable first to try and fix this issue. I will do a complete teardown as you suggested and look for faults in case I am not able to solve this problem by just replacing the flex cable.
Thanks a ton!
Hi @mgupta70 ,
This link may also be of interest to you. Read the last post at the bottom of the page.
댓글 달기
귀하의 답변을 추가하세요
Mohit Gupta 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 11
전체 시간: 2,916
