주요 콘텐츠로 건너뛰기
저렴한 Samsung Galaxy A3 스마트폰 2016 버전. (모델 번호: A310F).
59 질문 전체 보기
Power on from motherboard
Hello,
I have a Galaxy A3 2016 ( 310F) with a broken LCD. The phone is pretty much destroyed everywhere so I have not intention of re-assembling. I have connected the new display and when I connect the USB cable the display lights up with the battery % charge. When I press the home button the same screen pops up.
However I seem to be having issues actually booting the phone.
I tried it like this guide:
https://youtu.be/yIp51gcTcpQ?t=882
But that doesn't seem to do anything.
Are there any other ways of booting the phone from the motherboard, or am I doing something wrong?
Or do I have to take out the b atteryu and pop it back in?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
you can't boot 1 board from another. try powering the phone out of the housing connecting the 2 power pads instead of the power button
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
@fdtech the video you linked to will only work if the rest of your phone works. In the video they are checking a new display to a known working phone. If your's is a beat up as you make it sound you may have some deeper issues going on. You do want to start showing us what you are working with. Post a couple of images with your question so that we can see what you see. Use this guide 기존 질문에 이미지 추가하기 for that.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
FD Tech 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 17
전체 시간: 672
