주요 콘텐츠로 건너뛰기
2.2, 2.4, 2.5, 또는 2.6 GHz Core 2 Duo 프로세서
20 질문 전체 보기
Only powers on without Ram
Hi,
I have a problem with my old MacBook Pro a1260. It won't start... When I'm pressing the power button the fans are spinning for one second, if I'm holding the power button the fans are spinning for maybe 5 seconds. But when I remove the ram it makes the one no ram installed beeb.
I also tested other ram modules ( 2GB 800mhz) .
Maybe someone can help me with my good old MacBook:)
Best regards
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 5개
Have you tried cleaning the Connectors Between the Ram and the Motherboard?
Maybe that was the solution or my heating of the graphic chip
Thanks man :D
Cause an old Mac like that is sure to collect a lot of Dust xD
Thought I'd add an Answer xD
댓글 달기
답변 1개
가장 유용한 답변
Due to your Laptop being as old as it is, It most likely built up a lot of Dust, Open it up an clean all the connectors. I-Fixit Has great tools for this Job! https://www.ifixit.com/Store/Tools
Good luck and I hope it goes well!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Tom 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 85
