주요 콘텐츠로 건너뛰기
모델 A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 또는 3.8 GHz Core i5 또는 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K Display. 시스템이 매우 유사하므로 이전 iMac Intel 27" Retina 5K Display (Late 2014 & 2015) 안내서를 참고하십시오.
What kind of SSD fits my Mac?
Hello from Europe !
I have almost the same question !
iMac 5k i7 / 18.3 late 2017
What kind of SSD blade fit with my iMac ?
APPLE SSD SM0128L
  • Révision : CXS7CA0Q
  • Numéro de série : S3CWNY0J946659
  • Largeur du câble : x4
  • Vitesse de la liaison : 8.0 GT/s
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 3개
Sadly Apple is the only source for the PCIe/NVMe x4 blade SSD's. While you could put in a PCIe/NVMe x2 blade SSD you won't get the same throughput.
it seems that patience is a virtue!
I'm waiting!
I changed the disk 2 TB for a 2.5" SSD and I boot on the 128 g ...
there will be a builder to make us that !!!
like 512 or 256
Thank you for your answers
I have the same iMac as you just i5. OWC have what you want. I’m buying their OWC Aura Pro X2 2TB and OWC Mercury Electra 6G 2TB SSD. The 2TB SSD as my OS X (Mojave) drive and the 2TB PCIe Aura as my audio recording drive.
댓글 달기
답변 3개
선택된 해법
Best to just get an external Thunderbolt SSD RAID drive. In the long run it will be cheaper.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I want to upgrade the storage to a NVME ssd and a ssd and remove the fusion drive. But I don't want to loose any information that I have on my iMac. Can you please help me with this.?
댓글 달기
가장 유용한 답변
I don't believe the are any third party blades available for this machine yet. Your only option may be to ask Apple. Call 1-800-MYAPPLE and ask.
Be prepared and in a sitting position when getting this news to avoid passing out.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
There are several adaptors at Ebay or Amazon for around 10-20 Euros.
I'm using a sintech adaptor to use a normal M.2-NVMe SSD (Samsung Evo 970 Plus) in my 2019 iMac. No problems at all.
For Samsung SSDs, be sure, you have the very latest firmware on your SSD installed (i'd used a Windows laptop and an external enclosure for updating the firmware) and you will need at least macOS High Sierra to support NVMe-SSDs.
For frequent firmware updates, i have a bootstick with Bootcamp/Windows, because absolutely no manufacturer supports firmware upgrades via macOS and only Crucial(Micron) is providing a Linux based upgrade volume.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
karbator 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 24
전체 시간: 3,184
