Wii will shut down by itself at random intervals?
Sometimes we can use the wii for hours, but it will randomly shut itself off and the power light is red. You can turn it back on and use it again, but then shuts itself off again randomly.
좋은 질문 입니까?
댓글 3개
My wii will shut its self off ( powerless) I done everything I knew how to do but it keeps shutting off can someone help me.
Alissa steward 의
Just solved this issue myself.
When WII U is on check to see if the fan in the back is running! If not, the fan is dead and the system is overheating. A simple fan replacement should solve the issue
randomrepairtech 의
Just in case anyone else is having this issue, **CHECK THE FAN IN THE BACK**
If the system is running, the fan should be running. If not it will need a fan replacement. The system is shutting down due to overheating
randomrepairtech 의
