주요 콘텐츠로 건너뛰기
High-end multimedia laptop by Asus.
9 질문 전체 보기
I need screws for bottom cover near hinges
Got a Asus N551Jq trying desperately to find a screw that will secure bottom case to the front case hinges stay shut. (the two holes on bottom cover) requires I believe two long screws anyone know where I can purchase this? Or know screw type looking everywhere.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
I already know about this but I don't know what size I need and postage is ridiculous to take a gamble.
댓글 달기
답변 4개
가장 유용한 답변
Hi all,
just in case anyone needs it in the future.
Red: 2 screws (M2.5*10L) / connect bottom - hinge - topcase
Blue: 4 screws (M2*5L)
Purple: 2 screws (M2*3L)
Here you’ll need 2 longer screws (M2*16L)
These 6 screws (M2.5*4.5L) connect hinges to the bottom case
Basically, this list is applicable to both gaming (ROG G551 / GL551 / G58 series) and non-gaming (N551 series) models. Some minor differences may exist for TOUCH models.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
hey do you have something like this for the asus fx504gm model?
댓글 달기
And a bit more detailed overview for the FX504GM:
Let me know if you need more info about some other screws for this laptop.
Cheers!
해당 답변은 도움이 되었습니까?
점수 2
댓글 6개:
perfect thanks! do you also know the screws that connect the hinge to the lcd back(behind the lcd bezel)
@Dante Xavier, yeah, you'll need 2x M2*2,5L for the top and 4x M2,5*3L for the underside of the LCD cover.
Just to add, LCD panel should be attached using 4x M2*2.5L.
Cheers!
So in total 8 x M2,5*3L for the both hinges in the bottom left and right to be connected right? Also 2x M2*2,5L for the top of each hinge to the back lcd cover?
@Dante Xavier, nope, just as said before 2+4 is for both hinges.
Take a look - I've added a picture of how it should look like :)
thanks so much! also for the hinges in the second picture is that 4 on each side for a total of 8?
댓글 1개 더보기
댓글 달기
Hi,
Don't know if this is a help to you or not.
Here is a link that shows ''all'' the parts that are available for your laptop.
Scroll down and click on the screw link to get a list of the screws and their sizes,
e.g. M2.5*10L = metric screw 2.5mm wide x 10mm long
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hi,
Well there are only two long screws sizes mentioned and since they are a standard metric size suggest you try the local hardware store.
Either M2*16L or M2.5*10L
댓글 달기
Hi @Dante Xavier
Not the same detail as above but here are all the screws sizes available for the laptop model.
Just select the "Screw (14)" checkbox.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Adam UKGaming 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 2,597
