주요 콘텐츠로 건너뛰기
Wi-Fi 전용 버전의 Apple iPad Air(모델 번호 A1474)입니다. 스페이스 그레이 또는 실버 색상으로 제공되며 맞춤형 A7 프로세서가 탑재되어 있고 16, 32, 64 및 128GB 용량으로 제공됩니다.
20 질문 전체 보기
Ipad Air A1474 has backlight but no image
Ipad Air A1474 has backlight but no image.
The tablet is turned on, there is sound, the backlight is visible, but there is no picture.
This happened after changing the digitizer and I guess the reason is that I did not isolate the battery before.
I found a missing component near the lcd screen connector. I'm not sure if it's relevant to the problem?
Please, help me :(
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 4개
선택된 해법
The missing component is C7046 (0.1uF / 6.3V / 20% / 01005 / X5R). This capacitor is "inline" and used to filter the EDP_DATA_N<2> line and as such, it has to be replaced.
Such small components are difficult to DIY repair so your best bet is to find a repair shop that does micro-soldering repairs.
이 답변이 도움이 되었나요?
점수 5
댓글 6개:
Thanks for the quick response!
Is the absence of this capacitor causing no image, only backlight?
I think this is not the missing component because the missing component is between the two sockets J7000 and J6620.
C7046 you mention is on the outside of the J7000 ?
It doesn't show on the schematics available in the wild but it does show up in ZXW Tools.
Thanks for the response !
Thank you very much, it helped me a lot.
댓글 1개 더보기
댓글 달기
can not find this component on the schematics?
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I need the electric scheme of the ipad A 1474 can help me
댓글 달기
Good afternoon I'm in need of an information I'm having a problem on the capacitor c7046 of the ipad air model A 1474 I need the value of this component, can you help me.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Good afternoon I need the electric scheme of the ipad air model A1474 can help me
댓글 달기
Try simple things first like hard reset, put off battery press power button for 20sec, install battery again and try to turn on the device. If problem exist then seems you made a mother board damage, maybe you removed a small part like capacitor or filter. You need to see schematic and compare with your motherbowrd
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
George 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 4,008
