주요 콘텐츠로 건너뛰기
The Bose Wave Radio AWR1-1W, also known as the Bose Wave Radio I, was released in 1993. A countertop AM/FM radio system with a high performance stereo tuner and two independent alarms.
Adding a devise to my Bose wave radio/cd player
I want to hook up a record player to my radio /cd player ? do I need a preamp?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Hi @dfen ,
Yes.
A pre amp is required because the Bose Wave Radio AWR1-1W doesn't have a phono input (basically an inbuilt pre amp). It only has an auxiliary input. The turntable's phono signal output is not great enough for it to work on an aux input, even with the volume on the radio set to maximum
Just search online for an inline phono pre amp and select the one you want. Check that the pre amp comes with its' own power supply. Also if the pre amp has an external earth connection, be sure to hook up the turntable earth to the pre amp earth terminal.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
My CD is stuck in my CD player how can I get it out? Or where can I take it for repair?
댓글 달기
답변을 추가하세요
dfhdff23f24g24g 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 1,297
