주요 콘텐츠로 건너뛰기
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 질문 전체 보기
Can I fix a severed hold switch ribbon?
When replacing the battery on my iPod the battery was so stuck with the adhesive, that when it finally came loose, I severed the orange ribbon cable that goes to the hold switch. As such the iPod thinks it's eternally on hold. Can I fix it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
The ribbon cables are so small and delicate that repairing the ribbon itself isn't really an option. However, replacing the headphone jack/hold switch assembly (30 GB or 60/80 GB) is an inexpensive and easy repair. (If you successfully replaced the battery, this will be easy as well for you).
Good luck!
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
replacing the hold switch/headphone jack would be your best bet!
댓글 달기
You could snip the cable to add a finer cut, but this would not let the ipod go into hold, just turn on, and stay on
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
gary 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 11
전체 시간: 4,297
