주요 콘텐츠로 건너뛰기
Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
75 질문 전체 보기
Will Dell XPS 13 9360 motherboard work on my Dell XPS 13 9350?
I am replacing the motherboard on Dell XPS 13 9350 -i7 and currently have an option to install 9360 i7 motherboard. I think chassis (dimensions) are exactly the same, but I wonder if the new motherboard version works with older chassis/ older PC version?
Any advice/tip is welcomed.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
선택된 답변
UPDATE:
I was not successful installing this motherboard:
As was indicated by professional laptop service I went through, the potential problems are with the internal power supply and BIOS. And if the latter can be fixed, the former can seriously affect motherboard performance. The electric circuits diagram we found online did not explicitly indicate power levels, so we opted to use safest, ie older version of the motherboard.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
Hi. I think in this case you most likely need to replace the battery and make sure your screen and screen cable are compatible with the new motherboard. P.S.This is all pure theory.
Cheers,
Yevhen
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Did you ever figure this out. I am trying to figure this out as well
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi, I was not successful installing this motherboard:
Apologies for being unassertive!
댓글 달기
Hello,
I upgraded my 9343 to the 9360, I also bought the larger capacity OEM battery. The palm rest is also different, so buy a new one as well :)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Oikk Waclaw 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 13
전체 시간: 1,679
