주요 콘텐츠로 건너뛰기
The Xbox One Wireless Controller model 1697 was released in 2015 and replaced the model 1537 controller and fixed some of the problems found on Model 1537 controllers. The Model 1697 controller includes an integrated 3.5mm headset jack, which allows compatibility with most 3rd party headsets without the need of an adapter. This controller has been discontinued and replaced by the Model 1708 controller.
75 질문 전체 보기
Does anyone make a MicroUSB cable that works well with this controller
I've had this controller for 15 months and for the time I have owned it, I've never used the wireless because the Model 1697 controller only supports IR and USB connectivity. Because I don't own the wireless receiver and these controllers get terrible alkaline battery life, I've always used mine over MicroUSB to avoid having to buy batteries on a regular basis.
While this method works, I've been having a hard time finding a good MicroUSB cable that works well with this controller and doesn't wear out quickly.
The problem with these controllers is the connection is smaller then other MicroUSB connections. I have posted a picture of the connector in the controller for reference: (The Model 1697 controller is a minor refresh from the 1537, and the connector is the same)
Are there any good cable options I should look for that work well with this controller, or is it more or less impossible to find a good one that's 3rd party? The official cable from the Play and Charge kit doesn't work without the battery and doesn't work as a wired cable on the PC. It blocks 5V with the battery or 3.3V without the battery. The PCB in the cable is designed so it only works on the Xbox One console with the battery installed.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
How about soldering in a braided wire? https://www.amazon.com/dp/B012A1221Q/ref... just chop the micro USB connector off the end of this one.
Update (02/01/2018)
Actually, Here's a braided one for xbox 1 controllers. why braided? from my experience it extends the life of my apple cables soooo... https://www.walmart.com/ip/Microsoft-Xbo...
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
@nick not sure or not if you get a notification for updates, so here's this.
I'm not sure if Microsoft does the same thing they do with the Elite cable as they do with the Play and Charge cable. I doubt it, but I've never seen anyone with one yet to verify that.
댓글 달기
The ones on monoprice.com are really good and come with a lifetime warranty.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Nick 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 9
30일 전: 30
전체 시간: 2,526
