주요 콘텐츠로 건너뛰기
다양한 TV 브랜드 및 스타일 안내서 및 지원.
20 질문 전체 보기
Disassemble TV Image problem
A TV image is clear and becomes distorted The capacitors look intact And also sound electronic boards
Mise à jour (06/02/2018)
board t-con Sounds good As well cables ribbon
where is the problem
Update (02/08/2018)
liquid in that arrow
I thought it existed from a factory
Shall I wipe it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@medjdoub45,
If your television has image distortion issues, see the Insignia NS-24ER310NA17 Has Image Distortion problem page for possible causes and solutions.
Your images a bit fuzzy but it appears that this is happening to the right half of your screen. That could an issue with your t-com board or your panel. The t-con board is the one under the metal cover that has the two cables going to the panel.
Update (02/08/2018)
Your last posted image does not look like liquid but it looks like an overheated IC. Replace the T-con board and re-evaluate.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Looks like it's not an board t con
@medjdoub45 did you try a new board?
댓글 달기
답변을 추가하세요
medjdoub guerine 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 203
