주요 콘텐츠로 건너뛰기
Apple은 MacBook Air 13"를 2017년 6월에 새로운 Broadwell Intel Core i5 프로세서로 업데이트하여 성능과 배터리 수명을 약간 향상시켰습니다.
423 질문 전체 보기
No video capture devices were found in System Information
Hi,
The built-in camera of my MacBook Air 2017 stopped working.
I was able to use the camera of my laptop with Skype or FaceTime. It was working very well.
I went to About This Mac > System Report > Camera: No video capture devices were found.
I tried to solve the issue using Terminal > sudo killall VDCAssistant. It didn't work.
Please help!
Thank you
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
First you system is likely still under warranty (one year for defective parts) so I would first visit an Apple Store to have them take a look.
If that don't pan out then you could try reseating the camera cable on the logic board to see if that fixes it (I strongly recommend you do this after visiting Apple). Here, the IFIXIT guide you'll need to follow: MacBook Air 13" Early 2015 Logic Board Replacement Follow the first three steps, then jump down to Step 22. Carefully remove it and then put it back in, reconnect the battery is it working now? If not you'll need a new display assembly as the camera is mounted within it and not easy to get to.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Hey so I only need to the step 23 or from 23 to the end? And seem like disconnecting the camera is from step 22?
@Lê Nghĩa - Sorry the guide was altered so the step numbers changed you only need to do step 22 after first disconnecting the battery.
댓글 달기
귀하의 답변을 추가하세요
Pierre 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 15
전체 시간: 4,378
