주요 콘텐츠로 건너뛰기
Repair guides and support for LED, LCD, HD and other Vizio TVs.
931 질문 전체 보기
Backlight is out but tv still works can see with flashlight
Vizio 55in E550I-B2E
Watching tv and it just went out..waited one day and tried to see if it would come back on and it didn’t I thought it was completely black until I used a flashlight and could use the remote to still do things..I haven’t checked for sound..I’m just trying to figure out is it backlights or should I just get a new tv
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 8
댓글 2개
I changed my power supply board Still no picture only if u use flashlight
My nephew soldered mine ice cause there’s a piece that comes loose. I’m trying to find the video to it so he can fix it again. Does anyone have the link?
댓글 달기
답변 3개
가장 유용한 답변
@west12 definitely fixable. If you can see that picture with a flashlight, you lost the backlight. This is most commonly because of a failed power board. A replacement board cost ~$80USD and the replacement is straight forward. Remove the back of your TV after you unplug it and see if everything is properly connected. You can post some images of your boards and the layout of them on your TV set with your question. Use this guide 기존 질문에 이미지 추가하기 for that. It will allow us to see what you see. That way we can guide you further if needed.
해당 답변은 도움이 되었습니까?
점수 4
댓글 6개:
Ok I added pictures and I did check sound sound still work and picture does too with flashlight but no backlight so should just get that fixed?
I definitely would. I'd start with a power board replacement. while you have your board still connect etc. check the voltage on CN201. Multimeter in DC mode, on 50V scale and negative probe to ground positive to the 20V pin. Let us know what voltage you are getting.
Think if I just buy the power supply board I should be ok?
YEs it absolutely could be. You check the output the way I've described 2 comments up;-)
Did replacing the power board fix the problem?
댓글 1개 더보기
댓글 달기
Check Where the led inverter board connects to power supply. The connection on the power supply half has weak joints and will be loose. Just re solder the joints and youll get your back lights back.
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
I like this cos makes sense, my only problem is where's the circuit board?
@Kit Ilsley this model does not have an LED inverter board. So you need to find something that will work for your TV. It will always be better for you if you ask your own question. That way you may get an answer that is personalized to your device and your situation. https://www.ifixit.com/Answers/Ask
I can hear and see TV as long is there is no light it's not a bright reception
Thanks for your input it was a cable wasn't in properly...
댓글 달기
https://youtu.be/bmvFaVPz1gI Link to you tube that will fix Vizio backlight
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kw 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 57
30일 전: 293
전체 시간: 75,939
