주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
iPhone 6s backlight pins
Hello. I wish to find out which two from the four pins from the LED backlight actually use 16v. Which is plus and which is minus? I have a backlight issue that it's to expensive to repair around here and need a cheaper solution. Unorthodox maybe, but this doesn't involve motherboard soldering.
Update (02/08/2018)
Thanks. I figured it out. Since they are LEDs... They don't get burned when the polarity is wrong. So I found out that the first and the third contacts, starting from upper side, were those I wanted. Again, I didn't pay attention to polarity. It worked. If it didn't, then I just needed to solder the wires the other way. I have tested with a 16v transformer from a printer and from an iPhone 4 and 6. iPhone 4 would only power up half of the LEDs. But you MUST have it already connected, or else it will only send juice for a fraction of a second. Tested on my tongue and with a power meter. It's good that it's only a jolt, so it won't blow up it's filter or whatever it has before the LCD connector. Was fun. Now I have 2 apples on a branch lmao.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I am not really certain what exactly you are asking; will you be trying to directly power the backlight?
The backlight circuit is one anode (driving the ~16V) and two cathodes (return paths). That is what the circuit on the logic board looks like. If you are trying to connect directly to the soldered flex connector on the display, they tend to vary from one supplier to the next. One trick is to use a 9V battery or a DCPS and power the backlight directly to see what is what.
If this doesn't answer your question, get back to me with more details and/or pictures.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Alexandru Sirb 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,064
