주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
20 질문 전체 보기
I see a charging symbol, but the battery is not increasing more than 1
My iPhone 7 was working properly for 1/2 year but know, suddenly when I plug my phone to charge the percentage is stuck at 1% or in the best case 2% .
If I disconnect the phone from the charger it stay up for 40s and then shut down. There are times when the phone starts with 100% battery but when i remove the charger, the same problem, it s shuting down and show again 1%
The only thing I replaced was the front glass.I tried multiple cables and chargers without any results.I don`t know if it s the battery or the software, any help please? Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 2개
My phone is showing that it’s charging, unfortunately it’s stuck on 1% and isn’t moving up. What do I do?????
I hаd the same problem with my iPhone. These problems require a little bit of research on the internet.
Take at a look at this link: https://bit.ly/3hhNOJI
I followed this link and it was helpful.
댓글 달기
답변 4개
선택된 해법
You may have partially dislodged or completely removed some tiny components right next to the battery connector on the logic board. One of them is responsible for allowing the battery to communicate the charge state to the CPU. So take out a magnifying glass or loupe and inspect that area.
If that is indeed the issue, it will require a micro-soldering repair.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
It s not from the glass changing because that was 2 month back
It could have been partially dislodged months ago and finally broke off recently following a minor drop or impact.
If you are going to ask for help on a forum, don't discard answers out of hand without at least bothering to look first. The worst that can happen is that my hypothesis is incorrect.
Otherwise, use a battery checking program like coconutBattery to test the condition of the battery.
댓글 달기
가장 유용한 답변
You replaced the front glass, did you disconnect the battery before the repair? Any damage to the battery socket, are your cables seated properly within the frame, a pinched or shorted cable has been know to happen when closing the phone.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Try a new charger or get the charging panel replaced.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I don't have a clue what's goings on but my phone is doing the exact same thing and it's so annoying?!!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mija Andrei 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 4
전체 시간: 28,162
