주요 콘텐츠로 건너뛰기
Repair information for the Brother MFC-J6920DW wireless, multifunction inkjet printer. Model number: MFC-J6920DW. First available on Amazon in September of 2012.
23 질문 전체 보기
Horizontal lines out of alignment.
When i print, horizontal line are a different height every 2"
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Hello I’ve done this many times since the problem suddenly appeared - some of the nine example squares are identical so it is hard to do! The fault remains in that the printed image is in slightly offset stripes which, as I print music, is frustrating. Any ideas for a global fix? Cheers!!
I have been fighting this issue for months….I finally gave up and flushed the Brother printer and bought a new printer from HP. It was TOOOOOO FRUSTRATING tyring to fix with NO LUCK and NO HELP from Brother.
댓글 달기
답변 1개
선택된 답변
Hi @kdglover ,
Try a print alignment and check if this resolves the problem.
Here is a link. Scroll down to the section Checking the print alignment
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Kenny Glover 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 16
30일 전: 60
전체 시간: 4,384
