주요 콘텐츠로 건너뛰기
Fourth generation of the Toyota Pickup.
49 질문 전체 보기
Where is my fuel relay located?
Trying to replace my fuel relay for my truck and I can't find it. My truck used to run. Now I turn the key, it engages the starter but I don't get any fuel to the motor. I've replaced my fuel pump, fuel filter. Now it's down to either the worse for the pump or the relay. So I'm doing the relay.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Hi @skittleman88 ,
Not sure if this is relevant to your vehicle, but here is the service manual for a 1985 Toyota Truck - 4 Runner.
In the FI section it details the EFI system, including the electrical circuits. (see FI-65)
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Most likely under your bonnet (hood) will be another fuse/relay box. Look on the cover or inside the cover and it should show you the relay number. To test it just pull another relay that has the same ratings and use it. If it works it is your relay, if it doesn't work. Not a relay problem. Do you hear the fuel pump prime when you turn on your ignition? Have you checked your fuel pressure if injected?
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
William Ingram 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 15
7일 전: 38
30일 전: 127
전체 시간: 12,282
