주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1297 Unibody: 2009 상반기, 2009 중반기, 2010 중반기, 2011 상반기 & 2011 하반기
Shut off during startup
Hi,
I've a MBP 2009. With time, I have more and more difficulties to start the computer. When the computer is "cold" (no boot for some hours) and you press the power button, it tries to start (2-3secs), and then shut off. So I restart, again, again and again. With tries, it shut off later. Finally, I'm able to reach login screen. Then the computer is stable and I've no more shut off. I can keep it running during 24 hours without issues.
It's like the issue is happening when the computer is not "hot" or needs energy.
Thanks
Update (02/19/2018)
Here is the result :
It looks like the battery is fine ?
Update (02/27/2018)
Thanks @mayer. I replaced the battery with a new "genuine" one. Unfortunately, it doesn't solve the issue. It is still exactly the same. I'm also surprised that even with a new battery, if I unplug the magsafe, the computer shutdowns 2 or 3 seconds after that.
I'm now wondering if it's not an IC issue related to power on the logic board. Maybe you have some more hints ?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 4개
I notice that Coconut is showing a battery failure. I have the same machine on the bench now with a similar issue. But I also have the flu and unable to work on it yet. Will try to remember to get back to you with my finding in a couple of days. If I forget (highly probable, given the way I feel right now) shoot me a reminder in a few days.
Hello @mayer. Did you find a solution ? Thanks
You replacement battery is showing a failure while the original one didn't.
댓글 달기
답변 1개
선택된 해법
The 17" machines seem to need more of a startup boost the the 15 or 13 inch machines. I would look at the health of my battery by using Coconut Battery to see if it still has the strength to do the job.
http://www.coconut-flavour.com/coconutba...
UPDATE
It appears your battery is the original one and about nine years old. Frankly I would replace it.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Guillaume 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 7
전체 시간: 2,071
