주요 콘텐츠로 건너뛰기
모델 A1237 또는 A1304 / 1.6, 1.8, 1.86, 또는 2.13 GHz Core 2 Duo 프로세서
312 질문 전체 보기
Read Hard Drive 128GB Samsung 1.8" Sata LIF
My 1st Generation Macbook air has died. Overheated fault on the main board. Power Loop issues. I have retrieved the hard drive out of it.
How do I read it.
Get an 1.8" enclosure?
What do you suggest any links?
What's the difference between ZIF & LIF?
What the easiest cheapest just want to wipe the drive & put it back into
sell the parts on.
Update (02/21/2018)
Is this drive enclosure the thing to buy?
Amazon - DELOCK Gehaeuse 1.8 micro SATA USB 3.0
Delock Product Page - Further Specification.
Can anyone confirm? It looks like it can do the job.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 4개
Hi Jason, did you find the enclosure for the 1.8” SATA LIF? I have the same hard drive removed from Mac Air. Thanks
Mine had a Samsung drive in it. 24 pin LIF. Most are 40 pin. You have to be super careful to get the correct one. https://www.ebay.co.uk/itm/KALEA-INFORMA...
thank you. I will have a look at this :)
Did you manage to do this?
댓글 달기
답변 1개
선택된 답변
ZIF and LIF use the same cable.
The difference is the way the connector locks onto the cable.
This old thread should give you a better idea what you want.
HDD to SSD
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Jason G 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 1,061
